vitara/samurai exhaust manifold.
Re: vitara/samurai exhaust manifold.
Post by dan_2k_uk » Tue Sep 24, 2013 10:58 pm
Good job its off at the moment :lol:
Post by ScottieJ » Tue Sep 24, 2013 11:02 pm
Yep :lol: strange how mine doesn't foul the chassis but the one you had did though?
Post by dan_2k_uk » Tue Sep 24, 2013 11:05 pm
The 1300 one fouls the block!!!
Post by twiss » Wed Sep 25, 2013 7:41 am
ScottieJ wrote: Incorrect, it's there for an EGR system. Something that was not fitted on carb'd models therefore is blanked off.
I stand corrected!
Strange though as my original vit 8v carb manifold had it on there.... thats why I only noticed when I went to that SU manifold, which doesn't have it I don't think
gp7186
Post by gp7186 » Wed Sep 25, 2013 11:10 am
Am I right in thinking there are two different 1.6 manifolds and one hugs the block more. They have different flanges aswell. When I fitted my 1.6 16v I had to move the engine over to the drivers side by 10mm to allow my manifold to clear the chassis rail
Post by twiss » Wed Sep 25, 2013 11:21 am
gp7186 wrote:Am I right in thinking there are two different 1.6 manifolds and one hugs the block more. They have different flanges aswell. When I fitted my 1.6 16v I had to move the engine over to the drivers side by 10mm to allow my manifold to clear the chassis rail
Have you got the manifold with the single or twin downpipes? Ive got a single pipe one and its pretty tight as well!
gp7186
Post by gp7186 » Wed Sep 25, 2013 11:36 am
Yeah twiss mines the same as yours with the single downpipe It was very close until I fitted a spacer between the engine mount and block
Post by twiss » Wed Sep 25, 2013 11:42 am
I managed to grind down the flange a little bit on the down pipe, so now it clears OK with no spacer :)
Rhinoman
Post by Rhinoman » Wed Sep 25, 2013 9:32 pm
I used the SJ manifold which had the same size exhaust ports as the 1.6 8V (carb) head. The inlet ports were quite different.
mk1joe
Post by mk1joe » Wed Sep 25, 2013 10:13 pm
sounds like overall its worth me leaving the manifold as it is if the port sizes arent that different.
What about the rest of the exhaust though? is the vitara one bigger?
and i will also be getting the vernier calipers out soon to see how well my 1.3 manifold matches up.
