sj 413 running rough
groundhog
Post by groundhog » Sat Mar 01, 2014 7:32 am
Hi Have an offroad sj 413 it starts fine auto choke comes off after a while and ticks over lovely if you rev it it quite free but when you try to drive and put under load it splutters.Have changed the leads rotor arm cap and coil pack and plugs any advice please
Re: sj 413 running rough
Post by ROBBIE » Sat Mar 01, 2014 8:23 am
Have you checked timing?
groundhog
Post by groundhog » Sat Mar 01, 2014 9:46 am
no did think that but it runs lovely on tick over am going to check the fuel lines are clear and empty the tank,just think im missing something,will look attiming also.In the distributor housing there is something that looks like a cross between points and condensor what is that called and is it prone to fail ?Thankyou
Post by ROBBIE » Sat Mar 01, 2014 1:00 pm
Cant think what's in dizzy without looking, but its electronic ignition so no points. It can run ok with timing out but bad under load, are all the vac pipes connected and not split?
groundhog
Post by groundhog » Sun Mar 02, 2014 12:40 pm
found 1 return vac pipe with hole in and altered timing manualy by ear not light until it runs without have the flat spots i had to move it nearly all possible adjustment counter clockwise.now accelaerates better but backfires when you back off the throttle smells quite rich.blew out fuel lines and replaced a short section that wasnt proper flexable fuel pipe and was melting.am i liable to eat the plugs if the timing is far out from true ?.Havent timed a car for years think the last one was a beetle years ago is it any different because its electrnic ignition ? may need to get someone to do it for me.Thanks for your advice appear to be going in right direction
Post by ROBBIE » Sun Mar 02, 2014 3:57 pm
Shouldn't be different. I got a light as they aren't that expensive these days. The flat spots could be the carb
Mr bluesky
Post by Mr bluesky » Sat Apr 05, 2014 9:30 pm
Hi Robbie.
Have just signed up to the suzuki club UK this eve....hopefully to get some idea what my problem may be. I got a lovely Jimny (07) last summer. Its been great through the winter, what with all the flooding etc.
About 4 months ago i noticed an odd wering sound coming from under the center of the Jim. It sounds like another smaller engine is running, but only when i drive over 35 mph. It gets louder the faster i go. The noise has got very slightly louder as the times gone by.
Two local garages said it may be the Diff or wheel bearings or transfer box but they weren't sure. So i was advised to go to a gearbox specialist. They looked but couldnt pin point the noise exactly. obviously the costing of ripping out the Diff is time consuming, so was told to keep driving the Jim and see if the noise gets any worse. Thats fine, but id love to know whats going on. Has anyone heard of anything like this before?
Many thanks
Nicki :)
Post by ROBBIE » Mon Apr 07, 2014 11:20 pm
Mr bluesky wrote:Hi Robbie.
Many thanks
Nicki :)
Hi could be any one of those to be honest
