Noises coming from rear axle, now with added video
albertross74
Re: Noises coming from rear axle, now with added video
Post by albertross74 » Tue Jun 26, 2012 4:28 pm
cheers for all your suggestions and help guys, really appreciate it!
just jacked the rear up today and span the wheels with and without the aid of the engine and from using a big screwdriver like a stethoscope I listened to the diff which was pretty quiet and then more towards the end of the axle on drivers side and it sounded pretty grindy, after taking the wheel and drum off too the end bit of the axle with the 4 bolt studs on moves in and out a good 70mm or so.
Pretty sure it's gotta be wheel bearing, I hope!
Post by ScottieJ » Tue Jun 26, 2012 4:43 pm
I thought you said the wheel bearings were ok? :tongue: if you hold the wheel at the top and bottom/sides then wiggle it in and out or rocked it whilst jacked up I bet you'd have felt the play then. :doublethumbs:
Highlander
Post by Highlander » Tue Jun 26, 2012 4:50 pm
70mm???
albertross74
Post by albertross74 » Tue Jun 26, 2012 5:39 pm
haha, don't think I was vicious enough Scott!
sorry highlander meant to say 7mm!
:oops:
albertross74
any recommendations of where to order a new one from too please?
Post by ScottieJ » Tue Jun 26, 2012 6:51 pm
Muddyzook do a good price
Post by dan_2k_uk » Tue Jun 26, 2012 6:52 pm
All the bearing info is here if you want to go to a bearing supplier.
Dan
Post by Darrell » Tue Jun 26, 2012 6:52 pm
albertross74
Post by albertross74 » Thu Jun 28, 2012 1:48 pm
just ordered one from MuddyZook, cheers for all your help guys!
