1987 Samurai half shaft bearings!
littlesammy
Post by littlesammy » Mon Mar 17, 2014 2:57 pm
hi yall , after my outing at the devils pit a couple of weekends ago ive developed a nasty noise from the rear which has turned out to be the half shaft bearings on the rear driver side .
i do not know enough about it to tackle it and wandered if i needed a new half shaft or can i get the bearings done.?
cheers
liam
87 Samurai with added spice !
Re: 1987 Samurai half shaft bearings!
Post by ScottieJ » Mon Mar 17, 2014 3:26 pm
It's only around £30 for a bearing kit and doesn't take long.
http://www.suzukiclubuk.co.uk/diy/18-wh ... l-bearings
Ladaman
Post by Ladaman » Mon Mar 17, 2014 3:41 pm
If you are still on drum brakes, remember to fit the back plate BEFORE the new bearing :S
littlesammy
Post by littlesammy » Mon Mar 17, 2014 3:43 pm
cheers gentlemen., ive got rear discs. i only found out when i changed the pads which were almost non existent.!
timwilks13
SCUK Website Padawan
Post by timwilks13 » Mon Mar 17, 2014 3:48 pm
Ladaman wrote:If you are still on drum brakes, remember to fit the back plate BEFORE the new bearing :S
Surely no one has ever made such an elementary mistake!?
Yea remember that dude, it's a major ball ache trying to remove a new bearing with out a tool and not damage it!
littlesammy
Post by littlesammy » Mon Mar 17, 2014 3:56 pm
lol., ill pass that on to whoever i get to do it.!
cheers.!
Post by twiss » Mon Mar 17, 2014 5:15 pm
best thing to do is take the shaft and new bearing to a workshop with a hydraulic press... will take about 2 minutes and save a lot of hassle!!!
Ladaman
Post by Ladaman » Mon Mar 17, 2014 5:57 pm
twiss wrote:best thing to do is take the shaft and new bearing to a workshop with a hydraulic press... will take about 2 minutes and save a lot of hassle!!!
Or 20 minutes in the oven at 180 degree C, a pair of welding gloves, and some swift movements. :D
dazerede
Post by dazerede » Mon Mar 17, 2014 7:35 pm
I made a tool to put bearings on shafts it's a bit of tube a bit bigger than the size of the shaft and all I do is tap the tube down and the bearing down and I have used it twice and works alright
4” calmini lift kit :)
littlesammy
Post by littlesammy » Mon Mar 17, 2014 8:35 pm
thanks for all the replies , we've had a look at the pictures and my mate has a press in his work shop so all i gotta do is get a bearing from somewhere and well have a go at it at the weekend.!!
