Vitara Auto box & diffs
LewisL
Post by LewisL » Mon Apr 14, 2014 2:52 pm
Hi Guys
I have recently bought a 1.6 8v auto Vitara on a M reg.
Engine seems fine but the box feels like clutch slip in a manual car, so if i select reverse & try to reverse up my drive is struggles a bit. I assume its a 3speed transmission? it changes gear fine.
When accelerating I get a very strong smell which smells like peroxide(just like the wifes hair dye) anybody know what that might be?
Would a fluid change be benifical? if so what do i use? i might aswell do the front & rear diffs at the same time so what is best to use in them? is it stright forward enough to change out? I also own an mitsi evo & thats a right job to switch out the fluid!
thanks for any help
Lewis
Re: Vitara Auto box & diffs
Post by ScottieJ » Mon Apr 14, 2014 4:06 pm
I would start with changing the transmission fluid, should just be normal ATF in the gearbox i think.
sae 80w90 GL5 in the transfer box and diffs.
LewisL
Post by LewisL » Tue Apr 15, 2014 7:48 am
Thanks mate will get some oil in and switch it out see if that improves things
LewisL
Post by LewisL » Tue Apr 15, 2014 7:55 am
How many litres will each unit need?
vitara_mad
Post by vitara_mad » Fri Apr 18, 2014 7:06 pm
I have a auto box available if you needed 1 fingers crossed you don't but its there if u do
