refurbed starter? will a 1.0 starter fit a 1.3 help please
gamble63
Post by gamble63 » Fri Apr 17, 2015 4:28 pm
hey guys
need a new starter for our 1.3 and seen this on ebay
http://www.ebay.co.uk/itm/301390485277? ... fresh=true
refurbed bosch starter, anyone had any like this >? or is it worth buying a new one from somewhere?
the one ive got is moving far to slow to even move the engine, ive got the starter off the 1ltr but will it fit in the 1.3? test this motor and its turning like a gooden.
cheers :doublethumbs:
Ladaman
Re: refurbed starter? will a 1.0 starter fit a 1.3 help plea
Post by Ladaman » Fri Apr 17, 2015 7:06 pm
Didn't I send a starter with the engine? If it's that one, then it was fine before.
As I think you have rebuilt the engine, is the torque for turning the engine over correct, or is it a bit tight?
I've just had a quick look in the manual, but I can't find a figure for turning the engine over.
Does it turn the engine with no plugs in?
gamble63
Post by gamble63 » Fri Apr 17, 2015 7:10 pm
think it has died of death the starter you sent, ive had it on the bench and it spins up, just really slowly compared to the 1.0 ltr one next to it its like 1/8th the power.
i can turn the engine by hand with a socket no problem.
cheers
Post by ScottieJ » Fri Apr 17, 2015 8:45 pm
No 1L starters won't fit a 1.3, the flywheel spacing from the bellhousing is different
gamble63
Post by gamble63 » Fri Apr 17, 2015 11:02 pm
dammit Janet!!!!
cheeers
Post by twiss » Sat Apr 18, 2015 4:11 am
sure you are testing it right? if you just activate it by the small connector then it will spin really slowly...
you have to power the small connector and the big wire connector at the same time
gamble63
Post by gamble63 » Sat Apr 18, 2015 11:00 am
pretty sure i am but maybe not, ive got the starter earthed with a jump lead, then positive jump lead from the positive to the positive on the starter, then im bridging the positive jump lead to the small spade connector.
cheers
