New 84' Sj410 Not Starting
RocFreya
Post by RocFreya » Tue May 12, 2015 9:39 pm
Bought a non-runing 84' SJ410 & still haven't been able to get her going!
Cleaned the carb real good & can see fuel squirtin out fine.
New distributor cap
New plugs & wires
New starter
Compression testing all four cylinders at 150psi
For a while she was sputtering a bit but never actually ever started.
Now she wont do a thing but turn over real fast.
Where should I go from here?
84 Suzuki SJ410 ( North American Model )
Re: New 84' Sj410 Not Starting
Post by Jordi » Tue May 12, 2015 9:46 pm
Timing? Snapped cam belt? Is it sparking?
Post by donkeychomp » Tue May 12, 2015 10:57 pm
150 is a bit low but ok. Is the fuel stale?
Post by ScottieJ » Tue May 12, 2015 11:33 pm
as Alex says, make sure the fuel is fresh.
Also
Change the condenser and points, they are cheap and if the condenser is breaking down it can cause issues.
When you fit the new points set the gap to 0.4-0.5mm
RocFreya
Post by RocFreya » Wed May 13, 2015 12:22 pm
Belt looks ok, timing checks out alright too.
Fresh fuel being bypassed through
Inline spark tester shows spark on all four BUT maybe it aint strong enough?
I'm gunna change the ignition contact points asap along with the condensor.
Ether does absolutely NOTHING
Post by ScottieJ » Wed May 13, 2015 12:46 pm
If that doesn't work check that the timing isn't 180* out and it's trying to fire on the exhaust stroke.
it's an easy mistake to make and a very common one!
Post by donkeychomp » Wed May 13, 2015 8:13 pm
Brake cleaner in the carb? Gets most things started...
Martin86
Post by Martin86 » Fri May 15, 2015 11:03 am
donkeychomp wrote:Brake cleaner in the carb? Gets most things started...
:doublethumbs:
Post by ScottieJ » Fri May 15, 2015 11:54 am
Well if everything else is set up and working.
RocFreya
Post by RocFreya » Sat May 16, 2015 11:43 pm
Ok, I bought a new contact point set for an 87 Samurai because SJ410's have extremely limited parts here..
My distributor appears to only house a pickup coil & ignitor - no contact point set like I was expecting.
The inside of the distributor was in good shape & I cleaned it up even better.
I may be severly overlooking this - but I have not been able to find any other contents in the distribuotor - just the signal rotor and governer weights located underneath the pickup coil. My shop manual also mentions no contact point set like the one I mistankenly purchased for a Samurai.
* Timing looks good - air gap is correct width - inline spark tester shows spark
Distributor w/ pickup coil & ignitor
New 87 Samurai ignition contact point
Pickup coil & Ignitor from 84 SJ410 shop manual
