Steering wheel shake
Eltoon
Post by Eltoon » Tue Sep 20, 2016 7:11 pm
SJ413 Got a shake at about 40 mph, it goes after about 50 and feels like wheel imbalance but finally got round to having them done today - the guy said they weren't really much out of balance anyway and I've still got the shake. The wheels themselves have a couple of mm of play on them when moving them from side to side or top to bottom when jacked up which I don't think is too bad? Any suggestions what what would cause a shake? Prop shaft? Cheers
Re: Steering wheel shake
Post by twiss » Tue Sep 20, 2016 7:14 pm
Wheel bearings, kingpin bearings, or steering joints usually.
When you wiggle the wheel top to bottom, is it the wheel and disk moving? or is it the whole hub including the brake caliper?
Wheel and disc indicates wheel bearing, entire hub means kingpin bearings.
As for steering joints just give everything a wiggle and look for play
Post by ROBBIE » Tue Sep 20, 2016 9:39 pm
Check every nut and bolt is done up tight, steering, shackles and u bolts
Post by ScottieJ » Tue Sep 20, 2016 10:17 pm
Get the alignment checked as well, too much toe can cause a wobble.
Eltoon
Post by Eltoon » Thu Sep 22, 2016 3:29 pm
Thanks for input. I know nowt about steering and kingpins, it's all Greek to me! Assuming the kingpins are ok - the play was very slight, a mm or 2 at most so can anyone give me a simpletons guide to checking the steering? It does have loads of play at the steering wheel but that I believe is pretty normal? Ta
ferris
Post by ferris » Thu Sep 22, 2016 10:19 pm
Could be a UJ on the prop shaft. I would take the rear one off and check the UJs move freely in both directions.
zook123
Post by zook123 » Fri Sep 23, 2016 8:35 am
Kingpins me thinks, or at least 99.999999% of shakes on the Jimny are the Kingpins|!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Eltoon
Post by Eltoon » Sat Sep 24, 2016 11:14 am
Oh 'eck...anyone got The Halfwit's Guide for Idiots to Fixing kingpins?
Post by twiss » Sat Sep 24, 2016 8:17 pm
Eltoon
Post by Eltoon » Sun Sep 25, 2016 12:41 pm
Thank you!
