Coil problems
Pishadeperro
Coil problems
Post by Pishadeperro » Fri May 04, 2018 1:12 pm
This is my engine....it's not what the LJ80 came with I know, but when the did the engine transplant did they fit the right coil .....it started and ran in a fashion for a while and now it dosn'nt....I suspect the coil but this engine appears to be listed with a coil with another bit on top (technical name forgotten!)
Anyone any idea what type of coil it should be for this engine
I'm pulling my hair out with this anus.....it's been almost 18month of heartache and I'm still not there,
Pishadeperro
Re: Coil problems
Post by Pishadeperro » Fri May 04, 2018 1:15 pm
not sure what I typed but it certainly wasn't Anus!
Re: Coil problems
Post by Darrell » Fri May 04, 2018 10:43 pm
You typed in J e e p but without the gaps ;)
Think that's the 1.0L engine, the coil normally has a ballast resistor on the side to lower the voltage to the coil under normal running conditions which is bypassed on cranking to generate a bigger spark.
Re: Coil problems
Post by Darrell » Fri May 04, 2018 10:48 pm
I believe a 410 would have a coil like this....
Re: Coil problems
Post by ScottieJ » Tue May 08, 2018 11:17 pm
Has the distributor got points? If so then yes you have the wrong coil fitted and it’s probably fried the condensor and points.
I have loads of f8/f10 coils for the points type distributors if you want me to send you one to try?
Pishadeperro
Re: Coil problems
Post by Pishadeperro » Wed May 09, 2018 12:00 pm
Many thanks..I suspected it was an old coil as fitted before the engine swap...can I just buy a generic coil from ebay with a balast unit? and can't find the condenser, where is it?
Re: Coil problems
Post by ScottieJ » Wed May 09, 2018 11:25 pm
The distributor will only have a condensor if it’s a points distributor. You need to check which type of distributor is fitted before ordering a coil.
