410 Transfer Box Bearings
timwilks13
SCUK Website Padawan
Post by timwilks13 » Fri May 24, 2019 11:34 pm
Does anyone have a part number for the front output bearing? Can only find full rebuild kits but don't need it all.
Had the seal and circlip off hoping there would be a number stamped on the bearing but must be on the back side (or not at all) as I can't see one.
Re: 410 Transfer Box Bearings
Post by Darrell » Mon May 27, 2019 10:45 pm
Enter your VIN and go from there https://catalogs.ssg.asia/suzuki/?lang=en#
Post by Darrell » Mon May 27, 2019 10:47 pm
Using the first one in the 410 list it
works out as a 6205N 25x52x15 grooved. I guess you can confirm the 25 and 52 measurements. https://catalogs.ssg.asia/suzuki/?lang= ... VsSWQ9PTEw
timwilks13
Post by timwilks13 » Mon May 27, 2019 10:47 pm
Cheers Darrell! Anyone either got a 410 VIN number, or know if the output bearings are the same on the 413 and 410?
Post by Darrell » Mon May 27, 2019 10:55 pm
Unfortunately it needs to be your VIN to be accurate. I have no idea if the transfer box bearings varied over the years.
Post by Darrell » Mon May 27, 2019 11:22 pm
Appears they vary , have found a alternative number already.
Post by ScottieJ » Mon May 27, 2019 11:37 pm
Just use your vin Tim. Late 410, 413 and samurai transfer boxes (i.e. with 4wd light switch) all share exactly the same bearings.
It's only the early type 410 transfer boxes that are different.
timwilks13
Post by timwilks13 » Thu May 30, 2019 6:46 pm
Got the part number, took the old bearing into a bearing place and he had the right one in about 2 minutes without even asking for the part number so that was easy!
