Rear wash wipe pipe leaking.
Videng
Post by Videng » Sun May 04, 2025 5:37 pm
I've found the rear wash wipe supply pipe is split in the rubber flexible housing between the body grommet and the door grommet.
I think I may have to remove the offside rear internal panel to access more of the pipe to insert a 4mm pipe coupler and feed a new pipe to the rear door.
Has anyone had similar leaks ? I'll have to investigate how I remove this fairly large panel, am I right in assuming I'll have to remove the rear seats completely ?
Hey ho all fun now my trusty 2007 Jimny is showing its age !!
Re: Rear wash wipe pipe leaking.
Post by Rankine » Sun May 04, 2025 7:12 pm
I've never done it but if makes life easier. Worth trying to remove all fasteners you can see and trying first
