NASTY< NASTY < PROPSHAFT<Graunches?
Henry
Re: NASTY< NASTY < PROPSHAFT<Graunches?
Post by Henry » Mon Nov 01, 2010 9:29 pm
Sounds like it could be, get under and have a play....
Had one go on the 90, and boy did that clunk! :twisted:
Post by ScottieJ » Tue Nov 02, 2010 11:55 am
I would whip the prop off to check it, If a UJ has gone dry, chances are that you wont be able to tell the the prop still fitted.
If not it could be a wheel bearing that has suddenly failed?
Post by ScottieJ » Tue Nov 02, 2010 1:27 pm
with rear sj wheel bearings never presume they are ok :mrgreen: with large tyres like ours they can go from good to bad in days!
I check mine every week or two as I'm lucky to get 6 months use out of one!
4eye
Post by 4eye » Tue Nov 02, 2010 5:57 pm
Does sound pretty much like was i had....originally though it were my rear prop uj as it was a bit nackered to say the least.....got that fixed...still had noises fer bout a week(nowhere near as bad though) and my rear bearing failed on my drive home!....so like scottie said.....its worth checking mate 8-)
my ride.........:4eye:
