throttle cable
- samurai gary
throttle cable
Hi, I have just had to buy a new throttle cable for my samurai, i have brought the original part, but the nipple at carb end is too large to fit on the su throttle, i have seen on some forum that i need to grind it down, has anyone ever done this, if so do i use an angle grinder, i would imagine this would be difficult and too harsh or is there a simpler way of doing it......thanks
- Edweird
Re: throttle cable
If you're not enough of a surgeon with an angle grinder, I'm sure you could use a file instead, it'll just take a while.
Re: throttle cable
Vice and file me thinks
One false move with the grinder and the nipples on the floor along with your fingers
- samurai gary
Re: throttle cable
I agree, grinder is a bit dodgy. a file it is....
