best place to buy wheel spacers and inertubes?
Richie
Post by Richie » Sun Apr 28, 2013 8:14 am
Im in need of some 1 inch wheel spacers and 31 inch inner tubes. Anyone know which ones are the best to get?
Re: best place to buy wheel spacers and inertubes?
Post by ScottieJ » Sun Apr 28, 2013 9:40 am
Are the tyres Radial? If so you can't just use normal inner tubes because of the way the tyres flex it can create heat and rub against the tube eventually causing the tube to fail.
You can get thicker tubes designed for use with radial tyres but I haven't had much luck finding a supplier.
upjakscreek
Post by upjakscreek » Sun Apr 28, 2013 10:15 am
Iv put tubes in many a farm veichle and never had a problom, always on tubeless tyres aswell, the farmers seem to fit tubes by default even with brand new tyres, sometimes necessary because the rims were pretty shot but yea, unless running silly low pressure should be ok.
get a klebor or Michelin tubes and will be fine.
how ever if you do run low pressures they can rip the valves off the tubes if the tyre spins on the rim.
seen that alot aswell mainly on mowers and golf carts but it does happen.
Neil
Post by ScottieJ » Sun Apr 28, 2013 11:19 am
Yeah it would be fine for offroad and slow moving vehicles but if you use your SJ on road I wouldn't advise running normal tubes with radial tyres as the higher speeds create more friction and heat.
88SJ
Post by 88SJ » Sun Apr 28, 2013 2:04 pm
Richie wrote:Im in need of some 1 inch wheel spacers and 31 inch inner tubes. Anyone know which ones are the best to get?
Good news bud...l have a set of 30mm spacers that might suit you.
Not so good news is l'm at the airport about to grab some sun for a few weeks!!
I was gunna put them on ebay when l get back. Please pm me if interested
