Master Cylinder Info
NylonAdmiral
Post by NylonAdmiral » Mon May 13, 2013 9:21 pm
After Sunday's excursion I've found my brakes need looking at.
The pedal's going to the floor and needs pumping in order to stop. The brakes were only just bled when I replaced the rear brake shoes and I can't find any fluid leaks so I'm going to go with replacing the master cylinder.
It occurred to me that I still have the Vitara donor from my engine swap, does anyone have any idea if the Vitara master cylinder will fit or can be made to fit? :weld:
Thanks!
Re: Master Cylinder Info
Post by ScottieJ » Mon May 13, 2013 11:02 pm
He's the the vitara servo and cylinder can be made to fit, I have done it on mine, will dig out some pics for you when I'm on my PC tomorrow :thumbup:
NylonAdmiral
Post by NylonAdmiral » Mon May 13, 2013 11:10 pm
Sweet! Cheers, that would be really helpful. It would be great if I can use existing parts.
Post by ScottieJ » Tue May 14, 2013 12:32 pm
I can't find many pics but it's basically a case of enlarging the hole in the bulkhead and some new bolt holes.
oh and the original water valve for the heater will have to be moved :thumbup:
