Can anyone advise me on how to wire up my winch. I tested it when I first git it worked fine, after a strip down and extending wires I must have done something wrong because there shorting out.
Don't no if it matters but I have a britpart 8000lb with the new style solanoide not the old tin can ones,
Thanks in advance andy
Winch wiring ??
Re: Winch wiring ??
I removed winch from the Sj tyres it as it was wired and it works fine put it back in a it shorting out. Does the winch have to be insulated from the body
Re: Winch wiring ??
No it dosent need insulating from body. Are you using wire the same colour as on the winch? Just I know people who have extended using just one colour and getting crossed up somewhere lol
Re: Winch wiring ??
have you got any photos of the wiring.
also are you sure no wires are touching on the body of the winch.if you had a wire that wasn't insulated fully or had worn through/been damaged it could be contacting a metal part of the winch and causing it to short as soon as the winch touched your sj.
If at First You Don’t Succeed Skydiving Is Not for You
Re: Winch wiring ??
Ill check the wires g again 2morow ill get some pics up. Thanks guys
