carnt get gerbox out ??
some info would be great on getting my 410 gearbox out think I must be missing sumit, undone all bolts from engine n startet and box mounts , clutch cable and wires all off , gear sticks out removed the bolts off the prop from tranny box just carnt seem to get it back enough ,the top of the gearbox case is hitting the clutch, any ideas thanks
Re: carnt get gerbox out ??
Brute force. Engine may need tilting forwards / backwards a bit.
If your changing the engine anyway why not just remove that too?
cheers jordi , the lad who doing my engines on holiday at the min soo didn't want to take it out cos a don't no what I need to leave in for the vit engine , or does everything nee to come out , its the spi engine soo will all the wiring be no good , thankss
Everything will pretty much need to come out.
Best person to put any questions to would be Scottie i think.
thanks jordi will do think a need to ask exactly what I need to do just incase the mechanic doesn't no n just thinks he does lol thanks
- turbo-tom
Also remember engine mounts need to be changed possible I think something to do with the gearbox one aswell if its a really old 410.
thanks tom yer think scotti said my gearbox mount was ok its just wiring side not sure about
Well you've gotta use a 413 gearbox anyway so might as well pull the engine and gearbox out at the same time.
It depends how you want to do the wiring really, have you got the complete vitara spi loom?
Are you sure you are swearing at it enough?lukey4x4 wrote:some info would be great on getting my 410 gearbox out think I must be missing sumit, undone all bolts from engine n startet and box mounts , clutch cable and wires all off , gear sticks out removed the bolts off the prop from tranny box just carnt seem to get it back enough ,the top of the gearbox case is hitting the clutch, any ideas thanks
will try agen today yes all the wiring is there scottie for the vitara didn't get a key with the ig barrel though , dan a lost count on how many time a jammed my fingers when wriggling it about soo u can quess how much swearing there was lol
