hamer
Post
by hamer » Tue Sep 17, 2013 7:12 pm
http://tyresdirectuk.co.uk/shop/product ... =&id=31764
just bought them for my zuk naw i got the job of getting them to fitt lol
my 31" fitt good without rubbing so i guess if i cutt 1.5" out all arount arch and bulkhead then they would fitt same as my 31"?
they arrive tomoz but im flat out with wrk so will get them sorted on the weekend
windsor
- Winching along now
Post
by windsor » Tue Sep 17, 2013 7:22 pm
I had some 31 11.50 on and 31 10.50 where ok didnt rub to much but the 11.50 just hit the car on lock the with makes a massive difference you may need to cut more out
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
- The Boss
Post
by ScottieJ » Tue Sep 17, 2013 7:24 pm
You'll need to cut more than you think! fit the tyres and flex it up with full lock each way. cut then flex it up again and chances are cut again
What are you doing for gearing? You're SJ is really going to struggle to turn them if you don't sort that.
Also you might want to look into axle upgrades in the form of cromo front shafts and CVs and full float rear axles because 33" is the absolute maximum size you can run on stock SJ axles and you need to drive carefully to avoid breaking stuff with those
You're gonna have to drive very carefully with those tyres if you don't want to be breaking CVs every few trips out
hamer
Post
by hamer » Tue Sep 17, 2013 7:34 pm
ScottieJ wrote:You'll need to cut more than you think! fit the tyres and flex it up with full lock each way. cut then flex it up again and chances are cut again
i got floating axle on its way scottie..she all striped waiting for rob stor he said they be ready early this week
i have rocklobster fitted
that the plan im gna jack the wheel up til it sits inline with the 34 put something under wheel(31 still on)
then jack the other side till in hits my extended bump stop
then mark it with the 34" and sart from ther
if that makes sence ?? lol
hamer
Post
by hamer » Tue Sep 17, 2013 7:42 pm
cromo front shafts and CVs ...who does these and how much are they mate?
- The Boss
Post
by ScottieJ » Tue Sep 17, 2013 7:44 pm
Cool
you best get saving for those cromo front shafts and CVs then
Best bet is lowrange4x4 or Trailtough in the US, think it works out cheaper to import them than to buy from a supplier in the UK
It should be ok with just a rocklobster but you might find it needs to still be lower. Some 4.6 or 4.8 vit ring and pinions would sort it nicely
And yeah that's the way to do it! I was surprised how much extra I needed to cut out of my arches with the lost height and added flex from the YJs for my 33s
hamer
Post
by hamer » Tue Sep 17, 2013 7:53 pm
cool thanks mate il take a look
just sold a set of vitara diffs :(
- The Boss
Post
by ScottieJ » Tue Sep 17, 2013 8:06 pm
You need two fronts for the ring and pinions anyway
hamer
Post
by hamer » Tue Sep 17, 2013 8:14 pm
hence why only the front sold cant give the rer axle away lol
- The Boss
Post
by ScottieJ » Tue Sep 17, 2013 8:44 pm
What ratios are they? I might be interested?
