1.6 16v wiring harness
ikuzusdink
Post by ikuzusdink » Thu Jan 09, 2014 7:44 pm
wots the best way of stripping harness to just all wires for engine operation to ecu cheers chaps
ikuzusdink
Re: 1.6 16v wiring harness
Post by ikuzusdink » Thu Jan 09, 2014 10:39 pm
bloody wires everywhere not sure best way of doing it.
gp7186
Post by gp7186 » Fri Jan 10, 2014 7:52 am
Follow the link I left you in the question you asked in the electrical section it leads to a very comprehensive write-up which goes into massive detail and makes the loom job very easy id say I did mine in about 2 hours by just using the ecu pin out diagrams.
Post by ScottieJ » Fri Jan 10, 2014 10:52 am
I've got this to look forward to sometime in the next few weeks :armsup: can't wait to get rid of the SU!!!!
ikuzusdink
Post by ikuzusdink » Fri Jan 10, 2014 4:59 pm
well spaghetti junction here i come !!!! cheers chaps i'll give it a stab lol .
gp7186
Post by gp7186 » Fri Jan 10, 2014 6:26 pm
It aint as bad as it looks just follow the diagram from ecu pin location to each plug along the correct wire colour, remove what you dont need cutting wires most of the times at spliced junctions and removing the pin from the relevant plug using a small screwdriver. Before I started I labelled each plug so that when taping the loom back up I knew what needed to tee off where. A few supplies need to be put in and the fuel pump supply extending. I did the power upgrade using the main fuses from the vit to do away with the sj fuse wire. You will end up with about 30%-40% of the original loom left after modifications. If you need any help fire away il do my best
ikuzusdink
Post by ikuzusdink » Fri Jan 10, 2014 7:39 pm
cheers pal u been a real help this sites got some nice characters on it .
