Wots the difference?
- stevepsj413
When i got my first samurai it came with a load of spares, including a 413 rear axle, not the sammi one but the narrow one off an old 413, apart from being narrower are there any other differences, are the diffs different or wot, and if they are different is there any point in me keeping it? Cheers in advance steve
Re: Wots the difference?
Slightly different diff ratio. Apart from that much the same apart from the obvious narrowness.
The only thing that would be of much use to you for a samurai would be brake spares.
- stevepsj413
cheers mate.
