New 84' Sj410 Not Starting
RocFreya
Re: New 84' Sj410 Not Starting
Post by RocFreya » Sun May 17, 2015 1:00 am
I should have mentioned that my carburetor is for an 84' model with added ECU functions on it. Many of these added functions are disconnected & the matching inlets for them on the carb. capped off.
These include the A.B.C.V. ( Air Bleed Control Valve ) & the M.C.V ( Mixture Control Valve. ) PCV valve (Positive Crankcase Vent ) & VTV ( Vaccum Transmitting Valve ) - All of which are only partially functional & the previous owner disconnected in what looks like an attempt to disgnose the no start complex.
I have checked with a multi meter the
WOTS ( Wide Open Throttle Switch ),BVSV ( Bi-metal Vacuum Switching Valve ) and BTS ( Bi-metal thermal valve) all of which have power & appear to be operational.
I've disconnected the ECU as recommened by the shop manual in order of diagnosis yet no change in behaviour is noticed.
84 Suzuki SJ410 ( North American Model )
Post by ScottieJ » Sun May 17, 2015 1:55 am
I've never seen an SJ410 with an ECU or anything other than a basic side draught carb? None of the UK models had an electronic dizzy, all of them had points and a condensor.
Have you got some pics of the engine bay and carb.
Sorry about the confusion, I only just noticed that you wasn't in the UK and I've never seen a 410 with a different fuelling and ignition set up.
RocFreya
Post by RocFreya » Sun May 17, 2015 3:54 am
Would be pleased to
RocFreya
Post by RocFreya » Sun May 17, 2015 4:03 am
I would assume that dropping all the ECU add ons wouldn't affect performanc. - It's mostly just for emmisions I believe.
Rhinoman
Post by Rhinoman » Sun May 17, 2015 10:49 pm
You can't just drop the add-ons because the ECU controls the fuelling by adjusting the mixture control valve based on feedback from the lambda sensor.
If you aren't getting fuel then I would start by testing the fuel cut solenoid - assuming that you've already tested the fuel pump.
Post by donkeychomp » Sun May 17, 2015 11:30 pm
Does it have an alarm you don't know about?
RocFreya
Post by RocFreya » Sat May 23, 2015 4:38 pm
A new carb without ECU controls is starting to look more appealing.
RocFreya
Post by RocFreya » Sun May 31, 2015 11:25 pm
Got her started!
It was the timing - Cam & crankshaft were pretty off.
Repositioned the distributor, adjusted the valves & now she purrs.
