Thermostat opening temperature
cam12
Post by cam12 » Mon Jan 23, 2017 12:22 pm
I need to change the thermostat in my 2004 grand vitara 1.6 engine. Ive noticed 2 types that are available. One opens at 82 degrees and other type opens at 88 degrees.
Which is the best to fit?
zook123
Re: Thermostat opening temperature
Post by zook123 » Mon Jan 23, 2017 12:34 pm
I've just checked autodata and it says 88degrees :)
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
cam12
Post by cam12 » Mon Jan 23, 2017 12:38 pm
Thank you
Post by ScottieJ » Mon Jan 23, 2017 12:48 pm
if used offroad a lot it wouldn't be a bad thing to run the lower temp thermostat
cam12
Post by cam12 » Mon Jan 23, 2017 12:51 pm
It is only used on road. Generally for short journeys of 2-3 miles.
Post by Darrell » Mon Jan 23, 2017 2:53 pm
From the 2003 workshop manual..
gv temps.png (77.81 KiB) Viewed 6761 times
Post by Darrell » Mon Jan 23, 2017 2:56 pm
Bit more info..
cam12
Post by cam12 » Mon Jan 23, 2017 2:59 pm
Thank you for your help.
