Smokey Engine
Gardiner
Smokey Engine
Post by Gardiner » Sun Jun 16, 2013 6:14 pm
Ok so the 1300 engine I have decided to give her a decoke etc.
Stripped head down decoked it re-ground valves etc.
Put her back together started on the button sounded great then after 5 mins started smoking out of exhaust a proper oily smell.
Run it thinking it would clear and guess what it didn't :yuk:
Lifted head back off just in case a valve stem seal had shifted etc but was fine.
Put her back together and it was still the same.
So I think now maybe it is the rings not sure how taking head off could affect but it cant think what else it is ????
Any more ideas ??????
Izuki
Re: Smokey Engine
Post by Izuki » Sun Jun 16, 2013 8:18 pm
Firstly did you replace valve stem seals with new one when rebuilding the head.
Secondly when you took the rocker off to check was there a lot of oil in the cylinder head i have seen it before where the incorrect head gasket or missaligned head gasket can block the oil feed or return ports to the cylinder block, as excessive oil in the cylinder head could cause this problem by allowing oil up breather pipes into the inlet manifold.
Hope that helps.
sj413 samurai, pro comp springs, shackles, braided hoses, 10.5x31's bumpers, buckety seats and the best mod in the world a diesel lump (vauxhall 1.5td)
Rhinoman
Re: Smokey Engine
Post by Rhinoman » Sun Jun 16, 2013 9:10 pm
Have you checked the PCV valve? What were the bores like? sometimes if the engine is worn the extra compression just pushes oil past the rings.
Gardiner
Re: Smokey Engine
Post by Gardiner » Sun Jun 16, 2013 9:19 pm
Thanks for replies what is the PCV valve ???
Yes changed valve stem seals bores looked good !
Re: Smokey Engine
Post by Darrell » Sun Jun 16, 2013 9:41 pm
This little blighter !!
Gardiner
Re: Smokey Engine
Post by Gardiner » Tue Jun 18, 2013 5:56 am
Ok I have taken valve out it was a bit gunked up cleaned it can now hear ball bearing rattling.
I started her up again and thought great a few minutes later started smoking again :brows:
I have found my Compression tester and tested compression it not sure what reading should be but mine are
Bore 1 26 psi
Bore 2 25 psi
Bore 3 25 psi
bore 4 25 psi
What thoughts on this then ???
Re: Smokey Engine
Post by Jordi » Tue Jun 18, 2013 11:05 am
26psi??
Have a read here. Sounds very low.
http://forum.suzukiclubuk.co.uk/vi ... ion#p59796
Re: Smokey Engine
Post by ScottieJ » Tue Jun 18, 2013 11:28 am
was that with all plugs removed and the throttle held open?
If so then you have quite a major problem.
Rhinoman
Re: Smokey Engine
Post by Rhinoman » Tue Jun 18, 2013 1:04 pm
I find it extremely hard to believe that it would start if that was correct.
Ladaman
Re: Smokey Engine
Post by Ladaman » Tue Jun 18, 2013 1:29 pm
What were the valve guides like when you re-lapped the valves in? Did you check the valves for wobble. They may feel okay now with new seals on them as the will be flexible, but try wobbling them in the guides.
If you turn the head upside down when removed, do they hold petrol? It might be that you have lapped the valves with worn guides and effectively "spoilt" the existing valve seats, this will cause a loss of compression.
As Rhinoman says, that reading is very low, so surprised it runs too. Can you borrow another gauge to check the readings?
